sfpegasus
Jan 24, 2017Tutor
ReadyNAS 312 ERROR System: Fan fan2 in enclosure Internal speed is below threshold
Ever since upgrade to 6.6.1 have been getting this error every week or so. Teltale sign is fan considerably louder than normal. System: Fan fan2 in enclosure Internal speed is below threshold ...
FramerV
Jan 28, 2017NETGEAR Employee Retired
Hi sfpegasus,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
sfpegasus
Jan 30, 2017Tutor
I'll cross-post this here as well. These errors are being generated by the antivirus upgrade in 6.6.1. Disabling the antivirus has returned my system back to normal. The antivirus upgrade in 6.6.1 is buggy as all hell. It's apparently the cause of my other post "RN 312 Firmware 6.6.1 Strange backup errors".
Monitoring the antivirus definition file updates led me to find that my failures were happening right after these updates.
