lcdl_255's avatar
lcdl_255
ReadyNAS 3138 - Discard volume(s) - inaccessible volumes help
  Hi all,   I had a disk fail {4} and another {2} disconnect afterwards in a four disk X-Raid setup, and seem to have botched the resync.    The data volume is split into data0 {1,2,3,4[missing?...
  • StephenB's avatar
    Oct 01, 2025
    lcdl_255 wrote:
    I did not.
    A power outage, voltage fluctuation, or temporary hardware failure, is all I can think of.
    I replied to your PM.
    A power failure or a hardware glitch could account for it.  As I noted in the PM, there are two CMD timeouts (one for each disk) that show up in smart_history.log shortly after the failure.
    BTW, I was thinking that perhaps your 3138 was one of the ones included in this service note:
    But I checked your NAS serial number, and it is not in the range given in the note.
ProSupport for Business
