Lucos
Sep 29, 2015Aspirant
ReadyNas Duo V2 - After restart, nothing works
Hi guys, After restarting my ReadyNas Duo V2, I lost all my acces (SMB, DLNA, SSH, Dashboard). I perform an OS reinstall by boot menu, but nothing changes. I tested open ports from my Neywork, ...
DaneA
Oct 05, 2015NETGEAR Employee Retired
Hi Lucos,
I just want to share this link below where you can download the Windows version of the Data LifeGuard Diagnostics:
http://support.wdc.com/downloads.aspx?lang=en
DaneA
NETGEAR Community Team
Lucos
Oct 12, 2015Aspirant
Hy guys, thanks for your answers.
I tested several way to restore my data, but seems to be lost : the HDD is dead.
- WD Data Life guard was not able to analyze the disk
- HDTunes displayed bad sector from the begining of the disk that HDD Regenerator was not able to fix
- I try to clone the data partition of my disk that seems to be safe, but HD clone was not able to do it.
With a new disk the ReadyNas is now working.
I have been able to find the majority of my datas from differents backups on my PC, external HDD but not all :(
Now I'll wil keep 2 disks in ReadyNas and will make reguler external backups.
Luc
