santhudev
May 14, 2026Aspirant
readynas not able to reset password
I Forgot password am trying so many time to reset it but con't be
May 14, 2026Guru - Experienced User
santhudev wrote:I Forgot password
An OS reinstall will reset it to the factory default (with no data loss). The details vary, depending on the model - so please post what you have.
Note that since someone with physical access can get data off the disks w/o any password, it is reasonable to put the password on a label on the inside of the front door. Just something to consider.
