marioscimone
Mar 29, 2019Aspirant
ReadyNAS Pro 6 with 8TB WD Reds
I had an x-raid made on all 6 hdds, I was running raidiator 4.2.x, I had to shares. I made an upgrade from 4.2.x to 6.9.3 but I forgot to back up one of the two shares, is there any way to recovery t...
- Mar 30, 2019
marioscimone wrote:
Thank you for your clear answer, but I think I didn't started the thread clearly. I had onbord the 6 wd red of 3Tb each with the two shares on it. I made a copy of one share and thinking that was all I did the upgrade loosing all the data in the second share. The right question shuld be: Is there an yway to recover them?
Well, it depends on exactly what you did.
If you removed the 6x3TB drives, installed one or more of the 8 TB drives, and then converted to OS-6, then your original array is intact. If that's the case, you could mount the original array as read-only. Just power down the NAS, remove the new drives (labeling by slot), and reinsert the original disks (ideally in their original order). Then power up. When done backing up the data, power down and reinsert your new disks.
But if you did the conversion with the 6x3TB drives in place, then the conversion process would have reformatted the drives, created a different partition structure, and then installed a new file system on the data volume. If you are really desperate to get the data back, you could try Netgear's data recovery software (or RAID recovery software on a PC), but if you did the conversion with the original disks in place I think the odds are very poor - especially if you have copied back some files to the new data volume.
Apr 14, 2019Guru - Experienced User
marioscimone wrote:
but none of them see the smb share.
Recovery requires direct access to the file system - so the software can't recover from SMB.
You need to power down the NAS, remove the drives, and connect them to the PC. Likely you don't have enough SATA ports - if so you will need USB adapters/docks.
marioscimone
Apr 14, 2019Aspirant
But connecting them on pc with adapters then how do I recreate the x-raid and the correct sequence of disk?
- StephenBApr 14, 2019Guru - Experienced User
You don't. The RAID recovery software should figure all that out. Note you'll also need enough storage to copy any files that are recovered.
BTW - DON'T reformat the disks when you connect them to the PC. The RAID recover software will be able to access them, even though windows won't recognize the file format.
Your other option is to use Netgear's data recovery service.
- marioscimoneApr 14, 2019Aspirant
Thank you once more, I will try to understand how to activate the netgear recovery service.
Some information is here: https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
You can get support via my.netgear.com
