Vounce
Aug 27, 2012Follower
ReadyNAS Pro: System fan "spiking"
Hey, I have recently purchased a ReadyNAS Pro Business and it's has been running 3 1TB harddrives fine for a couple of days now, though I am having somewhat of a problem with the fans. Most of the ...
crookesa
Jul 25, 2013Aspirant
I have a ReadyNAS NV+ v2 running Radiator 5.3.8 with 2 3TB hard disks installed.
The temp of the disks are 42 & 37 degrees and the fan is spinning at 3320rpm.
It seems to run like that when I access the disk at all for anything and goes away once I reboot the NAS.
I have even set the disk spin down after 10 mins and it hasn't helped.
Anyone got any suggestions or can I roll back to a previous firmware because it seems to have happened since an update.
Cheers
Cheers
