Moto
Sep 04, 2015Tutor
Readynas Ultra 4 Plus no valid volume exists #25703630
Help! I had a power failure today, and now I am getting a "no valid volume exists" and cannot access any of the shares on the NAS, although they are listed in Finder on my Mac. However, I cannot acc...
JennC
Sep 04, 2015NETGEAR Employee Retired
Hello Moto,
Looks like you need data recovery contract. Maybe best to call support for more explanation.
Moto
Sep 04, 2015Tutor
The Level 2 tech said that there was some sort of problem mounting the drives, and that they could be manually re-mounted. However, it has been escalated to Level 3 and I have not heard from them yet. Apparently there is a failing drive that the Level 2 guy thought could be replaced and fix the problem . . . fingers crossed. He did say that he didn't think that the data was at risk.
- JennCSep 04, 2015NETGEAR Employee Retired
Hi Motto,
Yes it has been escalated from L1 to L2 and L3. I checked your records and found that L3 requries data recovery for the issue you have on the NAS. The L2 tech has not updated you yet, I saw that you ahve already asked for an update. L2 tech who escalated this case is probably not around yet. It seems some thing with the partition is the problem.
- MotoSep 04, 2015Tutor
Thanks for the response. But isn't that the whole purpose of a RAID array . . . to keep your data backed up if there is a failure of a drive? I now need to hire a data recovery person to pull the data off the 4 drives and reformat? Is that a remote service or . .
I still haven't been able to get in touch with someone to explain what is going on . . .
- StephenBSep 04, 2015Guru - Experienced User
As it says in the Ultra user manual:
Note: X-RAID2 does not replace backups. See the article, Preventing Catastrophic Data Loss at http://www.readynas.com/?p=3153.
X-RAID2 keeps your data available through routine disk replacements and also when you are expanding the storage capacity. But it is not enough to keep your data safe.
I do hope you will get your data back without too much cost. I believe the Netgear recovery service is normally done remotely, though I am not certain if they always can do it that way.
Also, I suggest getting a UPS for the NAS.
