neildeadman
May 23, 2013Follower
Replace drives in RN104
I have just bought a RN104 4-bay diskless NAS. I already had some 500GB disks so I put them in, which gave me around 900GB usable space. In my existing PC I had a 1.5TB disk which I have moved the con...
FireWalkerX
May 23, 2013Aspirant
you can maximum expand the nas with 8 TB after initial size, so how much you can add, depends on how you started,
lets assume you added 3x500 gb in, then later added 1,5T, then 8T - 1.5 equals max expandability to 6.5, or 3x 2T drives, unless you do a factory default when you add all the 2 T drives. so the best you could do is, dont add the 1.5T, but just slowly replace the 500G drives, one by one (let the nas resync between disk change)
hope it made sense..
