neildeadman
May 23, 2013Follower
Replace drives in RN104
I have just bought a RN104 4-bay diskless NAS. I already had some 500GB disks so I put them in, which gave me around 900GB usable space. In my existing PC I had a 1.5TB disk which I have moved the con...
FireWalkerX
May 24, 2013Aspirant
mdgm wrote:
FireWalkerX wrote: you can maximum expand the nas with 8 TB after initial size, so how much you can add, depends on how you started
That is a limitation with EXT4 and the older models. ReadyNAS OS 6 (the OS on the new devices such as the RN104) uses BTRFS and does not have this limitation.
ahh ok :-)
