Miraculix1
Aug 22, 2017Tutor
Resource busy
Hi, I just updated my RN516 with FW 6.8.0. I use my NAS with OSX Sierra, connected with SMB, and I do have problems deleting files useing finder. When I try to delete a file with OSX Finder I...
- Oct 11, 2017
I did not find a solution for this problem, today I updated to 6.9.0 RC1.
Now the smb access works fine.
This behaviour is not mentioned in the update notice, but it solved my problem.
mdgm-ntgr
Aug 24, 2017NETGEAR Employee Retired
Your system had a 2.2GB Musik folder on the root partition in addition to the one on the data volume.
I moved the one on the root volume to the admin home folder to free up space, but then lost access to your system. Can you turn Secure Diagnostic Mode back on?
Miraculix1
Aug 24, 2017Tutor
oh, sorry.
the system is back again
- Miraculix1Aug 24, 2017Tutor
thanks for cleaning up my root directory, I think you finished?
I still can not delete files useing finder.
Any idea what could cause the behavior?
- evan2Aug 24, 2017NETGEAR Expert
Cloud do you please access NAS using AFP on your MacOS?
Let me try to reproduce the issue (SMB access on MAC) in local.
