Miraculix1
Aug 22, 2017Tutor
Resource busy
Hi, I just updated my RN516 with FW 6.8.0. I use my NAS with OSX Sierra, connected with SMB, and I do have problems deleting files useing finder. When I try to delete a file with OSX Finder I...
- Oct 11, 2017
I did not find a solution for this problem, today I updated to 6.9.0 RC1.
Now the smb access works fine.
This behaviour is not mentioned in the update notice, but it solved my problem.
Miraculix1
Aug 28, 2017Tutor
Miraculix1
Sep 07, 2017Tutor
my problem still exists.
I have to connect my shares with afp to use them. This is a workaround but not a solution.
Does the actual beta adress this problem?
- mdgm-ntgrOct 02, 2017NETGEAR Employee Retired
Does this only affect particular file types? Are you using the SMB Plus app?
- Miraculix1Oct 02, 2017Tutor
it effects a lot of file types, checked it with .mp3 .m3v and .txt files.
Yes I use the SMB Plus App.
- Miraculix1Oct 11, 2017Tutor
