Miraculix1
Aug 22, 2017Tutor
Resource busy
Hi, I just updated my RN516 with FW 6.8.0. I use my NAS with OSX Sierra, connected with SMB, and I do have problems deleting files useing finder. When I try to delete a file with OSX Finder I...
- Oct 11, 2017
I did not find a solution for this problem, today I updated to 6.9.0 RC1.
Now the smb access works fine.
This behaviour is not mentioned in the update notice, but it solved my problem.
mdgm-ntgr
Oct 02, 2017NETGEAR Employee Retired
Does this only affect particular file types? Are you using the SMB Plus app?
Miraculix1
Oct 02, 2017Tutor
it effects a lot of file types, checked it with .mp3 .m3v and .txt files.
Yes I use the SMB Plus App.
- Miraculix1Oct 11, 2017Tutor
