gregwhite886
Jun 01, 2017Tutor
RN104 6.7.4 update causing problems on 2 x RN104
We have updated 6 ReadyNas 104 devices today with firmware 6.7.4 to patch the recent documented Samba vulnerability and 2 unts are now not functionning. 1 is stuck at 99% booting an we are unable to ...
mdgm-ntgr
Jun 06, 2017NETGEAR Employee Retired
So the problems are all resolved by disabling CHAP?
If not I can have a look at your system if you like.
If you're still having issues you could start by downloading the logs using RAIDar then sending them in (see the Sending Logs link in my sig)
akustikbuero
Jun 07, 2017Star
No I can't sent you any logs, because I dit an Factory Reset again. I have not time and no drive to find out by my self how to disable CHAP and read hours ans hours form some maybe-sorted-Problems.
I would like to know how to disable Netgear-Firmware-Updates in the future?
- akustikbueroJun 07, 2017Star
It's getting in a hateful regularity to fix Problems after firmware-updates from NETGEAR. How can I diable CHAP on the ReadyNAS? How can I disable automatic-firmware-updates?
- gregwhite886Jun 07, 2017Tutor
On my NAS's, firmware updates won't automatically install and have to be started manually so can't connect on that. As for CHAP, under my individual ISCSI groups, there is an option to untick, Require authenticators to initiate using CHAP. Do that for each group and reconnect your ISCSI drives.
That worked for me.
