Zurd
Jul 28, 2020Star
RN214 - Extremely slow with zip files
Hi, I have a ReadyNAS 214 and it used to be fine before but since about 6-8 months or so, it is extremely painfully slow to compress / decompress zip files. Is it normal? Why would it be so slow? Any...
Jul 29, 2020Guru - Experienced User
Sandshark wrote:
Total guess, but try disabling strict sync on the share. That causes Veracrypt to slow to a crawl on writes, and this may be related. If you are running SMB Plus and have enabled pre-allocation, you should also try disabling that.
Strict sync was enabled in my measurements, so that isn't it.
I don't see how pre-allocation would affect extraction to the local PC hard drive, since the NAS is only being read.
Could the zip file (or the share) be heavily fragmented?
How full is the volume?
Zurd
Aug 04, 2020Star
StephenB: I use 7zip too. Whatever you use will have a slight difference but that doesn't make much of a difference.
No 7zip in command line is not restrictive, I can output or zip with a command from and to a NAS, I've done it plenty of times on different computers, no idea what problem you're having but it should work.
You suggested that I disabled the bond so I did. I also removed one ethernet cable, so now I only have one ethernet cable plugged and here is the result with a 312.8 MB zipped file with 766 folders and 5517 files inside:
Laptop - Windows - From mechanical HD to mechanical HD = 16s
RN214 - SSH - From NAS to NAS =14.6s
Desktop - Linux - Wired - GUI - From NAS to NAS = 2m
Desktop - Linux - Wired - Terminal - From NAS to NAS =1m 54s
Laptop - Windows - Wireless - From NAS to NAS = 10m 14s
Ouch, that last one of 10m is quite something!
In my first test, if you compare the SSH extraction (56 seconds) to "Linux - Terminal" (48 minutes), the latter was 5143% slower.
In this test, the difference is 781% slower, that is much better than before! Looks like the bond0 I had wasn't good. It is true that I just plugged both cables in my router without any special configuration. However, it is still slow and still extremely slow in wireless (4206% slower), I'm having trouble wondering why that would be, why the network would make such a huge difference.
Sandshark: You suggested disabling "strict sync" which is in Share / Settings / Network Access / SMB / Advanced and here's the new results with the same file (I didn't rebooted the NAS, hopefully it doesn't matter):
Desktop - Linux - Wired - Terminal - From NAS to NAS = 1m 54s
Laptop - Windows - Wireless - From NAS to NAS = 10m 11s
In this test, the strict sync did absolutely nothing unfortunately.
What is strist sync?
https://www.samba.org/samba/docs/using_samba/ch11.html
This share-level option determines whether Samba honors all requests to perform a disk sync when requested to do so by a client. Many Windows clients request a disk sync when they are really just trying to flush data to their own open files. In this case, a disk sync is generally unnecessary on Unix due to its high reliability, and it mostly has the effect of substantially reducing the performance of the Samba host system. The default value for this option is no, which allows the superfluous disk sync requests to be ignored.
Because of this, I think it's a good thing to not have it enabled. If you install Samba, it is not enabled by default. I wonder why Netgear would turn it on by default.
StephenB: About fragementation, there is an option in Volumes / Settings to Defrag. I will try it, it will take time so new results will be posted later.
About the free space, I have one share in RAID 5, 4.19 TB of data and 6.70 TB of free space total of 10.90 TB so I have enough free space.
So it is faster right now but I still think something is wrong, it should be faster. In your test of extraction (which are different tests that I did) from SSD to SSD (12s) compared to NAS to NAS (80 seconds), it is 667% slower, huge difference.
- StephenBAug 05, 2020Guru - Experienced User
The net here is that with bonding disabled we are getting similar results. That's assuming all your tests are extraction tests. You could use -t to see how all the clocks compare.
One potential problem with round-robin bonding is that when you are going from 2 gbps->1gbps you create congestion (because the NAS can put data on the wire twice as fast as the client can accept it). At some point the switch ends up dropping packets, because its buffers overun. TCP congestion control then kicks in. TCP congestion control is designed to back off the send rate sharply when packets are lost - to prevent the possibility of a network collapse. So in this particular scenario, you end up underutilizing the network capacity.
You might want to check if you have ethernet flow control enabled in the switch (often it is not on by default). If you enable that, you could try re-establishing the bond.
The problem I ran into is that -o lets me extract to a different folder, but it is ignored when zipping (at least in windows). No matter what I typed, the zip file was created in the folder I was zipping (not in the folder I was in). So I could have extracted NAS->SSD, but I couldn't zip NAS->SSD. This was in windows. I didn't spend a lot of time fiddling with it, as I normally don't use the 7za command line. In any event, you can see the commands I actually tested, as they were included with my results.
This difference appears to be latency (you can see the huge gap between process times and global time in my slow extraction).
So at the time I chalked that up to SMB. Extraction presents a very different load from zipping (reading one large file -> writing lots of small files vs. reading lots of small files -> writing one large file).
I'd expected that disabling strict sync would help on that particular test. But you didn't find that, which is interesting. My suspicion is that SSD tiering on the NAS would fix it - something I've thought about using, but haven't gotten around to trying.
If I get to it, I might try a NAS->SSD extraction test.
Zurd wrote:
Because of this, I think it's a good thing to not have it [strict sync] enabled. If you install Samba, it is not enabled by default. I wonder why Netgear would turn it on by default.
For one thing, most NAS users aren't using linux clients. FWIW I think the Samba documentation might be over-touting "unix reliability". While my Windows systems often did crash many years back, I haven't found that to be the case with Windows 7 or Windows 10.
I suspect Netgear is prioritizing data safety over performance. With the setting disabled, more writes are cached in the NAS. If the power on the NAS fails (or if it crashes) those writes are lost. That can increase the odds that the RAID array will be out-of-sync (resulting in a corrupted file system or a RAID array that can't be mounted). If the NAS is UPS protected, then you probably can safely disable it.
- ZurdAug 05, 2020Star
Defragmentation took only 3h for 4 TB, that was fast!
2020 Aug 04 23:05:18 Volume: Defragmentation complete for volume z.
2020 Aug 04 19:55:07 Volume: Defragmentation started for volume z.And the results are exactly the same, so we can now rule out fragmentation:
Thanks for the explanation of the round-robin bonding congestion problem, that explains the problem quite well. I kind of wonder if I really need bonding (which I think is called 802.3ad), I only have a few devices at home, all on 1 gpbs except the laptop which is wireless, it seems pretty useless in my case.
But it would be a good test to have it configured and do another extraction test. However, my router has OpenWrt 18.06.2 and it seems possible to do it but a bit tedious so I don't think I will try that. Reference: https://oldwiki.archive.openwrt.org/doc/howto/mwan3
I understand what you mean by process time and global time and SMB latency, it really makes sense. The RN214 has USB ports, if it is possible to plug it as an external storage in my desktop, then it should be much faster if we bypass the network then? I'm reading the documentation but I can't see anywhere if you can do that. Can a RN214 works as an external hard drive with USB?
802.3ad is one method of bonding (also called LACP) - but that is not the method you were using. Not all switches support LACP.
You have to use ethernet, there is no way to connect to your PC using USB.
You could test with NFS and see if that has less latency.
