morelor
Aug 08, 2017Aspirant
RN31200 - 6.7.5 - Management service is offline
Data stored on our RN31200 has become inaccessible. Upon using RAIDar, I see that the "Management service is offline". I have tried the following in this order: Restart Reinstall OS Upgrade fi...
JennC
Aug 10, 2017NETGEAR Employee Retired
Hello morelor,
Have you already tried on another computer?
Cliff_MI
Aug 10, 2017Guide
I have a ReadyNAS Pro 2 with 6.7.5
I am having the same issue. I have tried all the same things.
I had lost a hard drive and decided to do a factory reset to remove the RAID array. After I did that, I have had this issue.
I have taken out the hard drive and reformated it to complete wipe them. I also used an spare drive just to see if it would install.
When I did this I was told that the drives were dirty and I need to format them again. I did that via Raidar.
Now all I get is the button for offline set up (in Raidar). I can't pull logs or ssh into the nas anymore (factory reset) That does not work. Just get a none responsive web page.
I even tried the USB install and that did not seem to do anything. All I have now is a NAS with blinking blue light.
Any other ideas?
Thanks
