Andreabe
May 24, 2023Follower
RN3220
I need to update motherboard bios to RN3220. The firmware is updated to the latest version. is there any way to do this? thank you
Redlikemethodz
Mar 22, 2025Guide
Did you ever figure this out? I'm try get to the bios to adjust the fan speed.
- SandsharkMar 22, 2025Sensei
Netgear has never said what the latest BIOS is or how to upgrade if yours isn't the latest. That's the case with all OS6 native ReadyNAS.
The BIOS doesn't normally adjust the fan speed, the OS does. OS6 uses a modified version of lm_sensors.
- RedlikemethodzMar 26, 2025GuideThanks! My RN3220's fans keep pulsing its rpms up and down and hover around 2200rpm. I'm trying to lower the fan speed and keep the fans steady. I can access the RN3220.conf sensors file and min fan speed is already set to 400.
- RedlikemethodzMar 26, 2025GuideI also have access to the BIOS but dropping the ATP 1 from 50 to 30 didn't do anything.
