Andreabe
May 24, 2023Follower
RN3220
I need to update motherboard bios to RN3220. The firmware is updated to the latest version. is there any way to do this? thank you
Redlikemethodz
Mar 26, 2025Guide
Thanks! My RN3220's fans keep pulsing its rpms up and down and hover around 2200rpm. I'm trying to lower the fan speed and keep the fans steady. I can access the RN3220.conf sensors file and min fan speed is already set to 400.
Redlikemethodz
Mar 26, 2025Guide
I also have access to the BIOS but dropping the ATP 1 from 50 to 30 didn't do anything.
- SandsharkMar 26, 2025Sensei
Try adding a hysteresis. I found that helped on my converted RD5200, which suffered a similar problem (while, oddly, my RN4200V2, which has the same motherboard, didn't).
- RedlikemethodzMar 26, 2025GuideLooks like it is already there? Also, I added max to all fans at 1500 and they are still running around 2200rpm.
Also I don't think lm-sensors is installed. I get command not found for lm-sensors and sensors.- RedlikemethodzMar 26, 2025GuideSs
