bedlam1
May 30, 2017Prodigy
Rsync Backup job NAS to USB drive suddenly displaying strange behaviour
The backup job in question has been running flawlessly 3 times a day for the last year.(alongside a similar job which is not mis-behaving) The only change I have made since this began is installing ...
- Jun 22, 2017
Did you check the permissions and owners for these particular MP3s? Right-click in file explorer, etc...
crazy_toy
May 30, 2017NETGEAR Expert
Hi badiam1
I dont understand job's setting , destination is 'remote' , host should be remote server host , not localhost
Could you please paste settings' screenshot?
Thanks
- StephenBMay 30, 2017Guru - Experienced User
He's backing up to a locally connected USB drive using rsync, so the "remote" destination has to use localhost.
It'd be far more direct if you could specify rsync with local source and local destination, but you can't do that.
- bedlam1May 31, 2017Prodigy
That's exactly correct @StephenB
Shame Netgear "experts" don't know that
Am still hoping for someone more knowledgeable to help withe the ACL problem
- jak0lantashMay 31, 2017Mentor
Does the issue in that thread look similar to what you're experiencing?
