hajo_s
Oct 04, 2015Aspirant
Streaming timeout on 104?
Hello community, Since recently - I suspect since firmware update 6.2.5 - my 104 disconnects streaming sessions after 30 minutes. I have turned off harddisk spin down to test but it still disconn...
- Oct 07, 2015
After further investigation I'm pretty sure now that those periodic cleanup scripts kill the streaming. I'm not exactly sure where php5 comes from -- is this a package originally bundled by Netgear or did I do something silly and installed it? I personally don't need it; unless another app I installed requires it. But since my apps are gone, I could remove php as well.
I have meanwhile changed the cron tab entry to run once a day when I sleep.
So thx once again Jenn, your guess about load was correct at the end :) Well, I learned my lesson. A Netgear 104 NAS is a NAS, not a full-blown Linux box. Can live with that...
hajo_s
Oct 07, 2015Aspirant
JennC
Oct 08, 2015NETGEAR Employee Retired
Hello hajo_s,
PHP is needed if there is an app that requires it.
Please feel free to continue posting in case it occurs again.
Thank you for your contribution to the community!
- hajo_sOct 08, 2015Aspirant
Thx Jenn,
It appears it was pulled in by an app I played around with then. I experimented with Wordpress at one point which is listed as a dependency. I removed Wordpress (with all other apps) so it seems it remained as an artifact. I'll probably dump it manually (via apt) then since I read you as the Readynas web front end not requiring it.
Thx again for the help!
