NTGR-OPS
Nov 25, 2018Tutor
System volume root's usage is 84%. This condition should not occur under normal conditions.
Hi,
I've seen many instances of this on the web, but no clear instructions on how to fix it. At the moment, I have no apps that are loading (but they should), and my system says no apps are in...
mdgm
Nov 30, 2018Virtuoso
These kinds of issues are usually following the same steps:
- Identify what's filling up the 4GB root volume.
- Remove the data that shouldn't be there (either delete/move to data volume)
- make config changes/firmware update (if needed) to stop it from filling up again for the same reason
- check for config corruption (can happen if the root volume gets full)
- verify it comes back up fine after reboot. If not check again to find out why that didn't happen and fix further issues.
In extreme cases formatting the 4GB root volume might be needed and there's another set of steps to do that properly.
It booting into safe mode would seem to suggest that the 4GB root volume might be completely full or can't get mounted for some other reason or there's some other issue leading to the RAID not being mountable.
The chat support team you're speaking to would be level 2. Advanced Level 2 (possibly), Level 3 or maybe even engineering (though there'd have to be a widespread issue or more serious issues encountered for it to get up that high) would be needed to attempt to fix a full root volume.
In safe mode you can enable Secure Diagnostic Mode under System > Settings > Support (especially useful if the NAS is at a remote site) or you could boot back to tech support mode for them to have another look. Either way would work for them.
NTGR-OPS
Nov 30, 2018Tutor
Hi,
It appears to be going into safe mode because the "installed disks contain an existing ReadyNAS installation that failed to start properly"
Booting into read-only mode, I can see the data.
According to the volume.log, the root volume is no longer full.
I'm afraid of doing anything myself as I've already tried OS install, and I can see my data. It's 13TB. The most important stuff is backed up, but it would be highly inconvenient to have to start over.
I'll continue to get someone that can help, but it feels like they are somewhat unfamiliar. It's hard to do this over chat. At this point, I'm almost willing to get paid support, but even that seems hard to get. Last year I had a contract (that has since expired) and received some excellent assistance. Can't seem to find those folks this time.
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 425M 3.2G 12% /
tmpfs 993M 0 993M 0% /dev/shm
tmpfs 993M 10M 983M 2% /run
tmpfs 497M 1.5M 495M 1% /run/lock
tmpfs 993M 0 993M 0% /sys/fs/cgroup
/dev/md127 22T 14T 7.4T 66% /data
/dev/md127 22T 14T 7.4T 66% /apps
/dev/md127 22T 14T 7.4T 66% /home
tmpfs 4.0K 0 4.0K 0% /data/Pictures/snapshot
- StephenBNov 30, 2018Guru - Experienced User
=== df -h ===
/dev/md0 4.0G 425M 3.2G 12% /It doesn't look full enough to me (so maybe some stuff is missing). Normally it is > 20%.
I suspect you'd need level 3 support, so you might ask via chat how to get that.
