viperhansa
Jan 01, 2021Virtuoso
Volume: System volume root's usage is 83%. This condition should not occur under normal conditions.
Hi all, Got a strange warning about 83% fullsystem root. Rebooted because RNnas was crashed/hung. Btw, why isnt rootfs showing up any more? Logged in via ssh and mounted root as mnt. Did: du...
- Jan 02, 2021
Hi all and thanks for all the ideas.....
I deleted mnt btw...... Nothing works now...... :smileylol:
Just kidding, understood that you missed the part about mounting in mnt.
Anyway, found the issue, update to plex that did some buffering into /var/tmp !!
Problem solved by installing new version of plex.
Now i'm back to 35% in os partition.
Kudos to rn_enthusiast and StephenB !
ps, i select my own post as solution... :-)
regards
// Hans
viperhansa
Jan 02, 2021Virtuoso
regards
// Hans
