Cazzbags
Mar 16, 2019Aspirant
Volume: System volume root's usage is xx%. This condition should not occur under normal conditions.
Hi all
I've found a few miscellaneous posts about similar problems but none that seem to relate here.
I'm getting the log error:
Volume: System volume root's usage is 92%. This condition should...
TikTok90
Mar 17, 2019Star
Hi I seem to be having the same issue. I'm running firmware 6.9.5. I've tried ssh to the device and using the command df -i i get the following in putty:
As far as I can tell from this I don't seem to have a problem as the highest usage is 23%. Can anyone provide any better checks for diagnosis? I'm not an SSH expert so step by step help welcome!
