Hornet305
Oct 04, 2014Aspirant
Reading NAS disk when NAS has failed
I have a ReadyNAS Ultra 2+ (Model RNDP200U). It no longer powers on. I verified that the external power supply is good. It has two 1TB drives that are mirrored. Is there some way that I can read th...
Hornet305
Well it sees the drive says it's Volume 3 (Linux RAID, Linux). But when I click on the drive it returns Can't Open Disk, Check the Disk and Try Again. The drive light flashes so I'm sure I'm looking at the right one. And when I use windows to disconnect the drive and then power off the external drive this disappears from the DiskInternals window. I also tried the "Open Partition" option with the same error. Under Properties it identifies the drive as having a GPT Partition. My windows drives have an MBR Partition.
I connected the disk to the PC with a USB 3.0 drive enclosure.
