Hornet305
Oct 04, 2014Aspirant
Reading NAS disk when NAS has failed
I have a ReadyNAS Ultra 2+ (Model RNDP200U). It no longer powers on. I verified that the external power supply is good. It has two 1TB drives that are mirrored. Is there some way that I can read th...
vandermerwe
Oct 04, 2014Master
Did you try both disks?
Check the disks using vendor tools.
You say the unit does not power on despite the power supply being ok and that this happened just after you completed a backup, correct?
What happens when you try to power up?
Is the unit still under warranty and did the drives come with it when you purchased, I suspect you are going to say you are not the first owner.
