Hornet305
Oct 04, 2014Aspirant
Reading NAS disk when NAS has failed
I have a ReadyNAS Ultra 2+ (Model RNDP200U). It no longer powers on. I verified that the external power supply is good. It has two 1TB drives that are mirrored. Is there some way that I can read th...
vandermerwe
Oct 05, 2014Master
I would first try option (d) in StephenB's last post before buying an overpriced Ultra 2+.
The Ultra 2+ would not wipe the disk if it were inserted while nas was off. You would need to verify the unit was working and update the firmware on it with a different disk first, before using the existing data containing disk.
