gggplaya
Jan 12, 2015Aspirant
Readnas Duo, upgraded to Nighthawk R7000 port forwarding
For several years now, i've been using the rock solid Readynas duo with a Dlink DIR-655 router, it's served me well and i used port forwarding to access the http share and download files while traveli...
mdgm-ntgr
Jan 12, 2015NETGEAR Employee Retired
Are you sure you configured the port forwarding correctly?
Did you forward just port 80 or also port 443 with your old router?
