gggplaya
Jan 12, 2015Aspirant
Readnas Duo, upgraded to Nighthawk R7000 port forwarding
For several years now, i've been using the rock solid Readynas duo with a Dlink DIR-655 router, it's served me well and i used port forwarding to access the http share and download files while traveli...
Jan 13, 2015Guru - Experienced User
It is odd to forward so many ports to port 80. I suggest https (using the secondary https port feature of the NAS). then forward just the secondary port in the router to the same secondary port in the NAS.
Other services (ftp etc) need to be forwarded to different ports.
Were you connecting with the web browser when the log snippet above was taken?
