gggplaya
Jan 12, 2015Aspirant
Readnas Duo, upgraded to Nighthawk R7000 port forwarding
For several years now, i've been using the rock solid Readynas duo with a Dlink DIR-655 router, it's served me well and i used port forwarding to access the http share and download files while traveli...
gggplaya
Jan 13, 2015Aspirant
mdgm wrote: Are you sure you configured the port forwarding correctly?
Did you forward just port 80 or also port 443 with your old router?
Yes, i have both port 80 and 443 ports forwarded to my readynas. Those are the only 2 i have set right now.
StephenB wrote: It is odd to forward so many ports to port 80. I suggest https (using the secondary https port feature of the NAS). then forward just the secondary port in the router to the same secondary port in the NAS.
Other services (ftp etc) need to be forwarded to different ports.
Were you connecting with the web browser when the log snippet above was taken?
Yes, that's the thing, i don't know where all those port numbers are coming from. I'm using the browser in my cell phone which worked in the past with the dlink, i could try setting my phone as a hotspot and logging in via laptop web browser. I also, did try typing the IP address with :80 at the end to hard code the port, but those port numbers still keep showing up. I'm not sure what the deal is there with this router.
