gggplaya
Jan 12, 2015Aspirant
Readnas Duo, upgraded to Nighthawk R7000 port forwarding
For several years now, i've been using the rock solid Readynas duo with a Dlink DIR-655 router, it's served me well and i used port forwarding to access the http share and download files while traveli...
Jan 13, 2015Guru - Experienced User
There is a traditional paper-clip reset. Look to the left of the LAN ports at the rear.
gggplaya wrote: The issue with this router is there's no hard reset
