BotanyBay's avatar
Aug 30, 2016
ReadNAS PRO 6 stuck at "Booting" after requesting download of logs
I have an ReadyNAS pro 6 which I noticed had failed complete a "pull backup" from a primary ReadyNAS Pro 6 because the file system of the backup unit became full.    The primary ReadyNAS Pro 6 is c...
  • StephenB's avatar
    Sep 01, 2016
    mdgm wrote:
    It sounds like you may have a large log file or perhaps even a full 4GB root partition.
    For these kinds of issues there is per incident support available, but remote access to your NAS would be required.
    If ssh is already installed on the NAS, you could access the OS partition yourself and likely find the file and truncate it.  However once the OS partition is full, you won't be able to install the add-on to enable ssh.
    So your other (painful) option is to do a factory reset on the NAS (which destroys settings and data), rebuild it, and restore the data from the primary NAS.
