stryper777
Feb 08, 2014Aspirant
ready NAS 102 : impossible to update firmware & to save conf
Hello, I've a readynas RN10200. It works perfectly, actually on firmware 6.1.5 I've no problem to acced to the NAS, I use Transmission for my torrent files (works perfectly) and I've opened ports ...
vandermerwe
Feb 08, 2014Master
Did you unzip the file before trying the manual update?
You do not need to open ports for OS6.
I think 443 is the port that OS6 uses, are you using it for transmission?
I would switch off transmission and try the firmware update again.
If that does not work, do an OS reinstall using the boot menu. This will not destroy data but it's adviseable to have a backup.
