stryper777
Feb 08, 2014Aspirant
ready NAS 102 : impossible to update firmware & to save conf
Hello, I've a readynas RN10200. It works perfectly, actually on firmware 6.1.5 I've no problem to acced to the NAS, I use Transmission for my torrent files (works perfectly) and I've opened ports ...
stryper777
Thanks for your answer,
FOr transmission, I use port 52000. I've tried to stop it, and install the update, same problem (automaticlly, and manually)
ANd yes, I've unzip the package before to try to do the update.
For the OS reinstall, using boot menu, whats is the method?
The problem is that, I can make a backup, cause it don't works too (I assume make a back-up it's to save the configuration, and that operation dont works...)
That's really strange, cause, I've this NAS since early december, and it seems to me that once, already, I done and update and it worked perfectly. Too, i've no problem to use transmission, to access to my files, etc, so it's really weird...
