stryper777
Feb 08, 2014Aspirant
ready NAS 102 : impossible to update firmware & to save conf
Hello, I've a readynas RN10200. It works perfectly, actually on firmware 6.1.5 I've no problem to acced to the NAS, I use Transmission for my torrent files (works perfectly) and I've opened ports ...
vandermerwe
Feb 09, 2014Master
Do you know where the certificate store is in the browser. I would check that it was generate by the right IP address.
Also you can check in the https settings and make sure the IP address is the NAS IP address.
The NAS IP must also be in the trusted sites list ( browser security)
I know how to sort certificates out with internet explorer and doing it on ie seems to remove the certificate problem on chrome.
