stryper777
Feb 08, 2014Aspirant
ready NAS 102 : impossible to update firmware & to save conf
Hello, I've a readynas RN10200. It works perfectly, actually on firmware 6.1.5 I've no problem to acced to the NAS, I use Transmission for my torrent files (works perfectly) and I've opened ports ...
Feb 09, 2014Guru - Experienced User
That is because IE and Chrome both use the same certficate store (the standard Windows SSL store). FireFox uses its own certificate store.
vandermerwe wrote: ...doing it on ie seems to remove the certificate problem on chrome.
From a user point of view, it is simpler to add a security exception to Firefox than IE and Chrome, as it can be done without worrying about certificates at all.
