leamal's avatar
leamal
Ready NAS Duo won't reboot
My ReadyNAS Duo won't. I fear that a power outage is the cause of the issue. I press the power button to start it and the fan starts and blows continuously. Blue power light is pulsing/flashing continuously on/off every (approx) 1 second. Not visible on my network. All I can do to get it to respond is to pull out the power supply.
  • leamal's avatar
    leamal
    Sep 07, 2017
    Stephen, thanks for your assistance. I had two drives in the box and tried them one at a time. It has booted with one of them. I'll try and get the failed one reformatted and reinstalled as a redundant drive.
    • leamal's avatar
      leamal
      Stephen,
      Thanks for the feedback, and sorry for my slow response. Have been away. RAIDar installed, disks removed and started up. RAIDar does see the box and status is "no disks detected". Fan has continued to blow for the last 5 minutes.
      • leamal's avatar
        leamal
        Stephen, I have just reinstalled the two hard disks and restarte dthe box. RAIDar now shows this mesage:
        RAIDar could not find any NETGEAR storage on your network. Check that your storage device is powered on and connected correctly. For more help, visit http://my.netgear.com.
ProSupport for Business
