Tommsy
Jan 14, 2019Aspirant
Ready NAS not booting - Boot from USB Failed
Hi have a readynas 10400 Model RN10400 which has stopped working with the following error on the LCD Screen
'Boot from USB
Failed!'
I have downloaded the Netgear Storage USB Recovery Utilit...
Jan 14, 2019Guru - Experienced User
The NAS can be finicky on which USB drive it will accept, so if you have a third one you might try that. Usually older drives work better than newer ones. If there are multiple partitions on the USB drive, you should remove them and create a single new one.
You could also try paid support via my.netgear.com.
Was there any trigger for this failure (for instace, a firmware update???).
Tommsy
Hi tried third USB, still no joy
I am going to try a fourth....
What should be done for it - network connected, disconnected??
Drives in / out etc?
