abl45
Jan 07, 2018Aspirant
Ready NAS NVX operating system update
I'm running a nine year old ReadyNAS NVX. Recently the NAS was 90% full so I replaced the two smaller two TB drives with 3 TB drives. The expansion went fine. However, when I went to check the sma...
Jan 08, 2018Guru - Experienced User
abl45 wrote:
However, when I went to check the smart disk functions on the drives the function returned no information.
That's an issue with Chrome. Try using a different browser (for instance internet explorer or edge)
abl45 wrote:
but Netgear should allow discussion of legacy hardware,
They do, and it's fine not to fill out the model field, as long as you include the model in the title or the post.
And your model is there - it is the RNDX4000. I've put the label on my reply.
- abl45Jan 08, 2018Aspirant
Thanks for the quick reply and sorry I missed the model number in the list. You are correct that it is a chrome issue but even IE has it's issues. In this case, the login screen is hidden behind the main window and you have to move or minimize IE to sign in. So much for universal browsers!
Thanks again
Alan
