midim
Apr 30, 2019Aspirant
Ready NAS OS 6.10.0 Backup jobs not working
After upgrading from 6.9.5 to 6.10.0 Hotfix2 the backup jobs which were successful when running 6.9.5 after the upgrade are not working any more and every job is reported as fail. The log reports:...
Apr 30, 2019Guru - Experienced User
- Are your backup jobs set up on the source system or the destination system?
- What backup protocol are you using?
- Are you specifying the remote system by it's name or are you using it's IP address?
I use rsync backup jobs set up on the destination, and the backup jobs worked fine after I upgraded that system to 6.10.0. I just upgraded the source system today, so I'll find out tomorrow if there is an issue related to the source.
- midimApr 30, 2019Aspirant
The backup jobs are type remote Windows timestamp source is with hostname, and the jobs are on the destination device and the backup date is stored on it
The destination is actually updated to 6.10.0. I have checked the credentials and connection between the destination and source the connection is ok. On a failed job when Test connection button is used the result is connection failed when passwrd is retyped the result is successful connection. After that when the job run for a minute is reported as failed with the error state from the previous post.
Clearly in the logs after some digging is visible the status of all jobs with the old firmware are good and after the update everything is failed.
To me is a firmware bug even there are tho hotfixes by now.
In addition I am running disk test now just in case. In other setup the firmware did not report 2 drvies failed. And after system access problems and manual disk test they poup up as bad.
Regards- StephenBApr 30, 2019Guru - Experienced User
Probably not something I would run into, since I use rsync and IP addresses. Are the sources hosted on Windows PCs?
One test you might try is modifying one job to use the IP address, and see if that works.
- 937carreraApr 30, 2019Aspirant
I am running 6.10.0 on an RN102.
There were no backup jobs on my system so I created one as a test earlier. I used windows timestamp and specified the source by IP address.
The backup worked. Have you tried creating a new backup job to duplicate an existing one and see if that runs to completion ?
