Tim-dk's avatar
Tim-dk
Ready NAS Pro no power
I have a Ready NAS Pro model RNDP6620-100NAS, it won't power on, I've removed and reinserted the disks, it didn't help. I read you could replace the PSU but I'm not sure which model I would get. Any ideas?
  • Hi Tim-dk
    Welcome to the Community!
    This old thread might help. Says there that you may need 24 pin extender and 3 4-pin molex connectors.
    Model mentioned was a SeaSonic SS-300SFD or something that might be similar today in the market.
    Hope this helps!
    Regards
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi Tim-dk
    Hope this helps!
    Regards
      • Sandshark's avatar
        Sandshark
        Sensei
        If you have a standard ATX supply, you can wire that up externally and see if it fixes it before you buy a new supply.   But the supply is the most likely cause.  The original Seasonic is no longer available, but there are other SFX supplies that will work.  Having the three 4-pin Molex "hard drive" connections is the difficult thing to find.
ProSupport for Business
