kbachler
Aug 18, 2014Aspirant
Ready NAS Remote - Notebook Can't Reset DHCP After Waking
This didn't seem to fit elsewhere. I have recently obtained an RN314, and it has allowed me to replace a WHS. It seems simpler and more reliable. I installed ReadyNAS Remote on my Lenovo X230 n...
Aug 18, 2014Guru - Experienced User
Obviously. ReadyNAS remote takes 5.x.x.x addresses. If your public internet provider happens to use addresses in that range, then you can't use remote.
kbachler wrote: Haven't had any issues with the IP address range...
Asking for help, and then replying by saying you're too busy to do anything is not a good approach here.
kbachler wrote: One of the reasons I chose this solution was because between job and other life concerns, I don't really need to tinker with a solution - I need a solution that works out of the box.
In my experience, all NAS do require more setup time than most other devices. Once set up, they tend to be very stable and reliable. In any event, setting up FTPS only takes a couple of minutes. If you need help on that, just ask.
