Neiljdc
Oct 21, 2012Aspirant
Ready Nas remote iphone
Hello, Bought my first ReadyNas duo a week ago set it up all worked fine including nas remote for iphone. But decided I wanted a ReadyNas duo V2 instead so returned the other and got one. Ev...
davedecali
Oct 30, 2012Aspirant
I had this same problem for a while. You want to make sure the .CIFS share is turned on. This is the only way your iOS will be able to see your ReadyNAS. At least that was my problem. I added and re-added until my face turned blue. Also un-installed and re-installed. Didn't realize I turned it off when I activated the .ftp shares (which should be left at anonymous)
Hope this helps.
David
Hope this helps.
David
