Neiljdc
Oct 21, 2012Aspirant
Ready Nas remote iphone
Hello, Bought my first ReadyNas duo a week ago set it up all worked fine including nas remote for iphone. But decided I wanted a ReadyNas duo V2 instead so returned the other and got one. Ev...
83SanDimas
Nov 02, 2012Aspirant
I have a ReadynNAS Duo V1.
I am using the latest version of the IOS app from the app store on my iphone and ipad.
I am able to connect from a laptop remotely
The Iphone app is different than the Netgear linked intructions, for instance the first screen says Log in, not connection
After logging in and selecting the bottom left option "ReadyNAS Remote", the Ready nas is not there (It was in the past even though I ould not connect) now it says "Please make sure you have added your ReadyNAS Remote user name to the allowed list in the ReadyNAS Remote Managment page on your ReadyNAS" It is added
Hitting the edit button on the top right does nothing but switch the button from edit to "done", the same message is displayed.
FTP On THe Go Pro works and works fast
Why does the native program not work and on the lighter side, when they release byg fixes what iphone did Netgear test it on?
Sadly, I do not think this app is a priority at all for Netgear.
Now that I have rambled here are my questions...
Does this app work on ReadyNAS Duo V1?
Can I set up a little office dropbox type system when this is working?
Lastly, what other options do I have? The WD MyBook Live I tested logs in perfectly but I am unsure how many users I can add.
Synology cloud looks cool but finding info about it is painful.
It is all about cloud... what is my best cloud option for a small office?
Thanks for any input
