FirstSon
Dec 08, 2021Aspirant
Ready NAS Ultra 2 does not turn on
I haven't had a NAS in use for about a year. Recently I decided to start it up again. I installed new disks in it and turned it on. Everything worked fine for about an hour. After that, the NAS just shut down.
When I try to turn it on, the power light comes on, the fan starts making noise and after about 10 seconds the NAS just shuts down.
It is also not possible to enter the boot menu. If you press the reset button and turn on the NAS, it also runs for about 10 seconds and then shuts down.
I gave the NAS to an electronics repairman and he says the problem is somewhere on the motherboard. The secondary voltages are trying to go up, the multicontroller is working, there is communication from the RAM to the CPU on the SPD. Most likely some of the capacitance turned into resistance, but to find which one without the controller schematic is very difficult.
Maybe someone has a schematic of the controller for this NAS board or had a similar situation and know how to solve it?
- SandsharkSensei
Schematics are not available.
- FirstSonAspirant
Okay. Perhaps someone has experienced a similar problem and knows where to look for the answer
- SandsharkSensei
You can try a different power brick, but iot really doesn't sound like that's it. I have a Pro2 (same hardware except the processor) with an internal 12V regulator that can only handle spinning up one drive. I didn't find anything promising to try to fix it.
