Vez's avatar
Vez
Ready NAS Ultra 4 plus slow write speed
My write speed from my PC is extremely slow, it appears to start off at the expected 100mbps per second, and then drops to single digits within seconds.....
I read that 6.9.1 fixed "interface timeouts on teamed NIC", but this I feel this is still prevalent.
Everything was fine prior to upgrading to 6.9.0
Thanks in advance :)
  • StephenB's avatar
    Is the PC using wireless or ethernet?  You say "100 mbps" - do you really mean megabytes per second?
    If you are using bonding, the try testing without the bond.  Also, if you are using jumbo frames, try disabling them.
    Also, if you are using a Windows PC, can you try testing with NAStester?  http://www.808.dk/?code-csharp-nas-performance
    • Vez's avatar
      Vez
      NAS performance tester 1.7 http://www.808.dk/?nastester
      Running warmup...
      Running a 400MB file write on X: 5 times...
      Iteration 1: 9.91 MB/sec
      Iteration 2: 7.56 MB/sec
      Iteration 3: 9.28 MB/sec
      Iteration 4: 54.40 MB/sec
      Iteration 5: 19.33 MB/sec
      Average (W): 20.09 MB/sec
      Running a 400MB file read on X: 5 times...
      Iteration 1: 97.96 MB/sec
      Iteration 2: 104.32 MB/sec
      Iteration 3: 98.37 MB/sec
      As said previously with Teaming enabled on the switch and NAS it has worked flawlessly until 6.9.0.  I will get an "unteamed" to follow.
      and yes I did mean 100MBs.
      • Vez's avatar
        Vez
        Okay, looks as though I hadn't set the teaming back to mode 3+4 (which is was prior to 6.9.0) - set to 2+3 as this gave the best performance on 6.9.0.
        I have now changed it back to 3+4 on 6.9.1 (prior to single NIC testing), and everything now seems to be normal with regard write speed :)
        Thanks for your assistance :)  (presently writing a 10gb file near on 100MBs - which I wasnt able to do this morning).
ProSupport for Business
