DaRealTinkeR
Mar 29, 2021Aspirant
ReadyDLNA - List is not updated
Hello, I got my ReadyNAS NV2+ v2 since several years now. My Media folder (c:\media) where I got all my videos has ReadyDLNA feature enabled. Now at the same time, I got my second smart-TV, and...
DaRealTinkeR
Mar 30, 2021Aspirant
Hello Marc and thank you for taking the time to answer.
I've got this equipment since 9 years now and restarting it doesn't fix it. Firmware is updated to the latest version yes.
It's already with a static IP address.
Mar 30, 2021Guru - Experienced User
Have you tried accessing the DLNA server with a different client? For instance, VLC on a PC or Mac.
There is a guide for this here: https://www.vlchelp.com/access-media-upnp-dlna/
- DaRealTinkeRMar 30, 2021Aspirant
Hello,
Using VLC with this link: https://www.vlchelp.com/access-media-upnp-dlna/ I don't see anything under "Universal Plug'n' Play"
However, using the Windows explorer works perfectly well, I can browse the NAS without any issue at all.
- StephenBMar 30, 2021Guru - Experienced User
DaRealTinkeR wrote:
Hello,
So we know SMB works, since you can browse the NAS. But not ReadyDLNA.
I suggest the next step is to download the log zip file from the NAS web ui. If you can't figure it out, you can ask Marc_V or JohnCM_S to take a look.
Don't post the log zip publicly. Instead send a private message (PM) using the envelope icon in the upper right of the forum page. Include a link to this thread, and a download link to the log zip (dropbox, google drive, etc).
- DaRealTinkeRMar 31, 2021Aspirant
Hello
Here is an update: today, everything was actually up to date! It turned out that refreshing (disable/enable DLNA) was actually veeeeery long. Now everything appears. Not very practical but at least it works.
Thank you to everyone that tried to help me :)
