linnallen
May 14, 2018Aspirant
readydr job failure: protocol error
Source & Destination ReadyNAS are in different locations and ReadyDR replicates over an Internet connection. ReadyDR Job is configured and can successfully connect to destination ReadyNAS and create ...
linnallen
May 16, 2018Aspirant
. Connection is not an issue. Port Forwarding has been setup and the two devices connect. A ReadyDR has been setup and will begin the transfer process. After some period of time, hours or days, the job will fail with eitehr an input/output error or a protocol error. This is the first protocol error received. Have done the internet searches and little or no information about this error, cause, or correction.
I have been using Ready Replicate for years and it works very well. In this case a Ready Replicate job will complete in about in about 10 hours; approx 125GB. The same data using ReadyDR so far has been running for 36 hours and transferred 62GB of data. Have tried going thru a VPN as well and job takes just as long if not longer considering VPN overhead on abndwidth. In addition ReadyDR is difficult to setup with incomplete documentation. Have worked with tier 2/3 support on two different occasions for days to get jobs setup. I now have ReadyDR setup and running on 2 of 3 customers and beginning setup/testing of the 3rd.
The source ReadyNAS is being used as storage for backup jobs instead of tape. The destination ReadyNAS is being used as offsite backup storage for DR; to replace taking a tape offsite. Ready Replicate performed this service well. The rate of transfer using ReadyDR makes using it very inefficient.
Anonymous
May 16, 2018ReadyDR needs port 443 open to authenticate with remote device for uploading ReadyDR key,port 5253 is for data transferring,port 80 is not needed for ReadyDR(my mistake in previous reply)
I will ask someone to update ReadyDR FAQ.
