Skeetboy1
May 10, 2018Apprentice
ReadyDR not working to offsite location
Our client has a ReadyNAS 716 (v6.9.3) and is using ReadyDR to backup their snapshots to a ReadyNAS 516 (v6.9.3).
This has been working perfectly until their insurance company told them to move the...
May 10, 2018Guru - Experienced User
As noted here, you need to forward port 5253: https://kb.netgear.com/31224/ReadyDR-FAQ Not said is that you also will need a DNS name (perhaps using a ddns service).
It is also possible to set a VPN between the sites (or to install ZeroTier on the two NAS). If you do use ZeroTier, your customers should choose to trust their security (as ReadyCloud users also choose to trust Netgear's security).
- Skeetboy1May 11, 2018Apprentice
Thank you for that StephenB.
It is still not working. I have setup port forwarding to the NAS on the remote router, I have also setup a DDNS account with ChangeIP.com, the router has been configured to use that DDNS account, and the ChangeIP record indicates that it has had a successful request from the router.
On the Source device (716), under the Destination Tab, the "Remote" button is blue, but the Host is showing as nasname.local
I assume that we need to change this also, but what do we put in there?
Thankyou
- StephenBMay 11, 2018Guru - Experienced User
You need the DDNS name of the remote router.
OK, still not working. Is tehre a format required? I literall have (e.g. skeetboy1.changeip.com) and nothing else.
