Buelligan
Mar 22, 2014Aspirant
ReadyNAD Duo know longer visible on network
Hey guys, I've been using a ReadyNAS Duo happily for the last several years. A couple of days ago I noticed I cannot see it on my Win'7 network listing anymore and a drive I have mapped is red X'd. We...
Mar 26, 2014Guru - Experienced User
I don't have much experience with Win 8.Though where I'd start on the PCs is deleting any credentials in the windows credentials manager, and re-entering the credentials you want to use with the NAS.
Then connect with \\NASNAME in windows explorer (and not bother with anything you see under network).
It might also be useful to enable ssh, and check the OS partition (which can't be done any other way).
