str8
Feb 09, 2013Aspirant
ReadyNAS - Access problem
Hello! After several years of using my ReadyNAS(duo), i "finaly" bump into a problem i need help with. I can't access my NAS? This likely caused by a major power outage a few weeks ago. Discs seems...
str8
Feb 17, 2013Aspirant
It worked perfect! :thumbsup: Also re-installed RAIDar to be sure, old password still active.
a_burger_with_fries wrote: you could try to do an OS reinstal through the boot menu the only thing it will clear is your network settings and it will revert your admin password back to default
http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
Your feedback helped alot. Thank you very much a_burger_with_fries :worship:
