Mojombo
Sep 11, 2012Aspirant
ReadyNas 1000s Documentation
Does anyone have a URL to download a manual for a ReadyNas 1000s User Guide and the Installation Guide? Thanks!!! :D Mojombo
Mojombo
Thanks StephenB & mdgm. I'll use these but wish I could find manuals that actually say 1000s.
It's always the little things that come back and haunt you. I made the mistake last night of updating the firmware on the 1000s then doing a factory reset to erase and start fresh. It completely trashed the firmware on the flash card. Had to pull out the card and roll back the firmware and re-sync everything. Now I have a stuck drive tray on the 1000s and I can't find a drawing with the secret slot you are supposed to shove in pin (not in the normal place) and slide the latch manually to pop it. It does seem like or look like my NV+ which I have popped drives out that way.
- May 12, 2025Retired_Member
